The role is a crucial one, because in order to synchronize and spawn on the same night, the creatures need to be able to stay in step with the patterns of the Moon on its roughly 29.5-day cycle — from Full Moon, when the moonlight is bright and lasts all night long, to the dimmer, shorter-duration illuminations as the Moon waxes and wanes.
When L-Cry was absent, the scientists found, the worms didn’t discriminate appropriately. The animals synchronized tightly to artificial lunar cycles of light and dark inside the lab — ones in which the “sunlight” was dimmer than the real sun and the “moonlight” was brighter than the real Moon. In other words, worms without L-Cry latched onto unrealistic light cycles. In contrast, the normal worms that still made L-Cry protein were more discerning and did a better job of synchronizing their lunar clocks correctly when the nighttime lighting more closely matched that of the bristle worm’s natural environment.
The researchers accrued other evidence, too, that L-Cry is an important player in lunar timekeeping, helping to discern sunlight from moonlight. They purified the L-Cry protein and found that it consists of two protein strands bound together, with each half holding a light-absorbing structure known as a flavin. The sensitivity of each flavin to light is very different. Because of this, the L-Cry can respond to both strong light akin to sunlight and dim light equivalent to moonlight — light over five orders of magnitude of intensity — but with very different consequences.
After four hours of dim “moonlight” exposure, for example, light-induced chemical reactions in the protein — photoreduction — occurred, reaching a maximum after six hours of continuous “moonlight” exposure. Six hours is significant, the scientists note, because the worm would only encounter six hours’ worth of moonlight at times when the Moon was full. This therefore would allow the creature to synchronize with monthly lunar cycles and pick the right night on which to spawn. “I find it very exciting that we could describe a protein that can measure Moon phases,” says Eva Wolf, a structural biologist at IMB Mainz and Johannes Gutenberg University Mainz, and a collaborator with Tessmar-Raible on the work.
How does the worm know that it’s sensing moonlight, though, and not sunlight? Under moonlight conditions, only one of the two flavins was photoreduced, the scientists found. In bright light, by contrast, both flavin molecules were photoreduced, and very quickly. Furthermore, these two types of L-Cry ended up in different parts of the worm’s cells: the fully photoreduced protein in the cytoplasm, where it was quickly destroyed, and the partly photoreduced L-Cry proteins in the nucleus.
All in all, the situation is akin to having “a highly sensitive ‘low light sensor’ for moonlight detection with a much less sensitive ‘high light sensor’ for sunlight detection,” the authors conclude in a report published in 2022.
Many puzzles remain, of course. For example, though presumably the two distinct fates of the L-Cry molecules transmit different biological signals inside the worm, researchers don’t yet know what they are. And though the L-Cry protein is key for discriminating sunlight from moonlight, other light-sensing molecules must be involved, the scientists say.
Researchers studying the lunar clocks of marine bristle worms rear the worms in the laboratory inside plastic containers filled with seawater. The worms are subjected to cycles of dark and light aimed at mimicking lunar cycles. In their natural environment, when these worms are ready to reproduce, they swarm to the surface and release sperm and eggs into the water. Worms that are ready to swarm start to swim frenetically, as shown in this video. Mating is highly synchronized to certain times of the month and night. CREDIT: M. ZURL ET AL / PNAS 2022
In a separate study, the researchers used cameras in the lab to record the burst of swimming activity (the worm’s “nuptial dance”) that occurs when a worm sets out to spawn, and followed it up with genetic experiments. And they confirmed that another molecule is key for the worm to spawn during the right one- to two-hour window — the dark portion of that night between sunset and moonrise — on the designated spawning nights.
Called r-Opsin, the molecule is extremely sensitive to light, the scientists found — about a hundred times more than the melanopsin found in the average human eye. It modifies the worm’s daily clock by acting as a moonrise sensor, the researchers propose (the Moon rises successively later each night). The notion is that combining the signal from the r-Opsin sensor with the information from the L-Cry on what kind of light it is allows the worm to pick just the right time on the spawning night to rise to the surface and release its gametes.
Resident timekeepers
As biologists tease apart the timekeepers needed to synchronize activities in so many marine creatures, the questions bubble up. Where, exactly, do these timekeepers reside? In species in which biological clocks have been well studied — such as Drosophila and mice — that central timekeeper is housed in the brain. In the marine bristleworm, clocks exist in its forebrain and peripheral tissues of its trunk. But other creatures, such as corals and sea anemones, don’t even have brains. “Is there a population of neurons that acts as a central clock, or is it much more diffuse? We don’t really know,” says Ann Tarrant, a marine biologist at the Woods Hole Oceanographic Institution who is studying chronobiology of the sea anemone Nematostella vectensis.
Scientists are also interested in knowing what roles are played by microbes that might live with marine creatures. Corals like Acropora, for example, often have algae living symbiotically within their cells. “We know that algae like that also have circadian rhythms,” Tarrant says. “So when you have a coral and an alga together, it’s complicated to know how that works.”
Researchers are worried, too, about the fate of spectacular synchronized events like coral spawning in a light-polluted world. If coral clock mechanisms are similar to the bristle worm’s, how would creatures be able to properly detect the natural Full Moon? In 2021, researchers reported lab studies demonstrating that light pollution can desynchronize spawning in two coral species — Acropora millepora and Acropora digitifera — found in the Indo-Pacific Ocean.
Shlesinger and his colleague Yossi Loya have seen just this in natural populations, in several coral species in the Red Sea. Reporting in 2019, the scientists compared four years’ worth of spawning observations with data from the same site 30 years earlier. Three of the five species they studied showed spawning asynchrony, leading to fewer — or no — instances of new, small corals on the reef.
Along with artificial light, Shlesinger believes there could be other culprits involved, such as endocrine-disrupting chemical pollutants. He’s working to understand that — and to learn why some species remain unaffected.
Based on his underwater observations to date, Shlesinger believes that about 10 of the 50-odd species he has looked at may be asynchronizing in the Red Sea, the northern portion of which is considered a climate-change refuge for corals and has not experienced mass bleaching events. “I suspect,” he says, “that we will hear of more issues like that in other places in the world, and in more species.”
10.1146/knowable-022223-2
Virat Markandeya is a science writer based in Delhi. He enjoys writing about unusual ecosystems, materials science and space history.
This article originally appeared in Knowable Magazine, an independent journalistic endeavor from Annual Reviews. Sign up for the newsletter.
