Every January, a tight-knit clutch of families and friends head for a barren, disused area of Cape Canaveral to reflect and remember. With almost religious reverence, they lay bright splashes of winter blooms near a gaunt concrete and steel hulk that memorializes one of the darkest days of America’s space past. The structure, slowly but surely decaying in the salty Florida air, is now overgrown by weeds and wild pepper trees. Clinging to one of its rusting limbs is a faded “abandon in place” notice.
Three engraved granite benches furnish their own voiceless words of tribute. “Launch Complex 34, Friday 27 January 1967, 1831 Hours,” one laconically reads. Another recalls the three astronauts who died on this spot more than a half-century ago. These three American sons — Gus Grissom, Ed White, and Roger Chaffee — were lost in appalling circumstances, yet their sacrifice helped facilitate the success of the Apollo program’s push to land men on the Moon.
An uninspiring spacecraft
Apollo 1’s crew knew their ship could never reach the Moon. It was never meant to. The barebones ‘Block 1’ spacecraft, intended only for Earth-orbital tests, had none of the navigational wizardry or docking tools necessary for a lunar voyage. (Those flights would await the more advanced Block 2.) But from the start, many astronauts disliked and distrusted Block 1 for its faulty wiring, bad software, leaky valves, and dozens of unresolved technical problems.
Prime contractor North American Aviation was roundly blamed for poor workmanship and lax safety standards. “A slick, bigtime bunch of Washington operators,” astronaut Tom Stafford cynically opined in his memoir, We Have Capture (Smithsonian Books, 2004), “compared to the mom-and-pop operation at McDonnell,” which built NASA’s earlier Gemini spacecraft. During Gemini, astronauts could talk to the boss, James McDonnell himself, but North American was a very different corporate beast.
Yet North American faced its own challenges, notably NASA’s mandate that the Apollo capsule should possess a pure oxygen atmosphere. This choice was less technically challenging than arranging an Earth-like oxygen/nitrogen mix, but it posed an extreme fire risk. Anything in the spacecraft that accidentally caught ablaze would explosively burn — truly a devil’s bargain.
Backdropped by this palpable sense of unease, 1967 dawned. Commander Virgil ‘Gus’ Grissom, America’s second man in space, was joined on Apollo 1 by Senior Pilot Ed White, the nation’s first spacewalker. Rounding out the Apollo 1 crew was Pilot Roger Chaffee, an energetic rookie. The plan was that they would fly a 15-story Saturn IB rocket into Earth orbit in late February for a two-week shakedown of Apollo’s myriad systems.
But Grissom harbored scant faith in his ship, branding its design sloppy and unsafe. Even the simulators never marched in lockstep with ever-changing software and hardware modifications to the spacecraft. His crew had a mocking portrait taken, their heads bowed in prayer, hopeful that the space gods might conjure some happy fortune. “It’s not that we don’t trust you,” they told NASA brass, “but we’ve decided to go over your head.” When a journalist asked what would make Apollo 1 successful, Grissom unsmilingly retorted that getting his men home alive was enough.
The night before an unpowered (“plugs-out”) test of Apollo 1 that took place Jan. 27, 1967, fellow astronaut Wally Schirra pulled Grissom aside. He too hated the Block 1 design. “If you get the slightest glitch,” Schirra told his longtime friend, “get outta there. I don’t like it.”
The fatal fire
On the afternoon of Jan. 27, clad in their space suits, the crew boarded the Apollo 1 capsule, perched high atop the Saturn IB. Grissom noticed a strange odor, like soured buttermilk, but air samples revealed nothing untoward. The heavy, two-piece hatch was sealed, followed by the rocket’s boost protective cover. Next, pure oxygen was pumped into the cabin.
The hatch caused headaches of its own. North American wanted a single-piece hatch, fitted with explosive bolts so it could be quickly opened in an emergency. But NASA, fearful that the bolts could misfire while in space, nixed this idea. An inward-opening hatch meant cabin pressure would help tightly seal it during flight, but the design also made it hard to open when on the ground. During simulations, even the super-fit White needed two full minutes to crank the hatch ajar.
The test went badly from the outset. A high oxygen flow indicator repeatedly triggered Apollo 1’s master alarm, and spotty communications between Grissom and astronaut Stu Roosa, seated in the nearby blockhouse, caused tempers to fray. At one point, Grissom bellowed with unvarnished angst: “How are we gonna get to the Moon if we can’t talk between two or three buildings?”
Sitting with Roosa was astronaut Deke Slayton. Seconds after 6:31 p.m. EST, Slayton saw something odd on his monitor. It was an image from a camera pointed at Apollo 1’s circular hatch window. But instead of a dark circle, it was illuminated, almost white.
Suddenly, the crew’s biomedical readings skyrocketed, indicating increased oxygen flow in their space suits. Other sensors detected a brief power surge. Then came the first call from inside Apollo 1.
It was Chaffee’s voice. And it was just one word: “Fire!”
Now the calls came thick and fast. “We’ve got a fire in the cockpit,” Chaffee yelled. “Let’s get out. We’re burning up.” His transmission ended with a scream that was blood-curdling both in its brevity and its agony.
Downstairs, on the launch pad’s first floor, technician Gary Propst looked at his monitor and saw White, arms raised over his head, fiddling with the hatch. Propst wondered why he did not just open the hatch. But to do so, White needed a ratchet to release multiple bolts. With only seconds available before the fire and smoke claimed him, he scarcely had time to loosen the first bolt.
It made no difference. Fire hungrily gorged Apollo 1 as pressures sealed the hatch with immense force. No man on Earth could have opened it under such circumstances.
