The basics of the 2024 total solar eclipse
The length of totality varies from one total solar eclipse to the next. That’s due to the fact that Earth is not always at the same distance from the Sun, and the Moon is not always the same distance from Earth. The Earth-Sun distance varies by 3 percent and the Moon-Earth distance by as much as 12 percent. The result is that maximum duration of totality for any eclipse between 2000 B.C. and A.D. 3000 is 7 minutes 29 seconds. (However, that extra-long eclipse doesn’t occur until July 16, 2186, so don’t get too excited for it.)
While the maximum length of totality during the April 8, 2024, eclipse won’t be that long, it’s still a worthy chunk of time: 4 minutes, 28 seconds. And as with the Great American Eclipse in 2017, everyone in the contiguous U.S. will at least be treated to a partial eclipse. In fact, as long as you have clear skies on eclipse day, the Moon will cover no less than 16.15 percent of the Sun’s brilliant surface — and that minimum coverage comes at Tatoosh Island, a tiny speck of land west of Neah Bay, Washington. But keep in mind, although our satellite covering any part of the Sun’s disk sounds cool, you’ll want to set your sights higher.
Likening a partial eclipse to a total eclipse is like comparing almost dying to dying. If you are outside during a solar eclipse with 16 percent coverage, you won’t even notice the Sun getting darker. And it doesn’t matter whether the partial eclipse above your location is 16, 56, or 96 percent; only totality reveals the true celestial spectacles: two diamond rings, the Sun’s glorious corona, 360° of sunset, and stars revealing themselves in the daytime.
