20. Yes, the Sun’s a lot bigger.
But it’s also a lot farther away. The Sun’s diameter is approximately 400 times larger than that of the Moon. What a coincidence that it also lies roughly 400 times farther away. This means both the solar and lunar disks appear to be the same size. But that won’t last forever. The Moon is slowly inching away from Earth, meaning that hundreds of millions of years from now, the Moon will appear too small to entirely cover the Sun’s disk. At that point, solar eclipse will be a thing of the past.
21. You won’t need a telescope.
One of the great things about the total phase of a solar eclipse is that it looks amazing to naked eyes. The sight of the corona surrounding the Moon’s black disk in a darkened sky is unforgettable. That said, binoculars at relatively low power still give you a close-up view — one that you should take advantage of several times during the event.
22. Nature will take heed.
Depending on your surroundings, as totality nears you may experience strange things. Look: You’ll notice a resemblance to the onset of night, though not exactly. Areas much lighter than the sky near the Sun lie all around the horizon. Shadows appear different. Listen: Usually, any breeze will dissipate and birds (many of whom will return to roost) will stop chirping. It is quiet. Feel: A 10°F to 15°F drop in temperature is not unusual. After all, the Sun provides a lot of energy to the surface of our planet.
23. Maximum totality is not the longest possible in 2024.
The longest possible duration of the total phase of a solar eclipse is 7 minutes 32 seconds. Unfortunately, the next solar eclipse with a totality approaching 7 minutes won’t occur until June 13, 2132. That eclipse, with a maximum duration of 6 minutes 55 seconds, will be the longest since the 7 minutes 4 seconds of totality experienced June 30, 1973.
24. The future is bright, but long.
The next total solar eclipse over the continental U.S. requires a 20-year wait until August 23, 2044. That one is visible only in Montana and North Dakota. Great total solar eclipses follow in 2045 and 2078. Those events have maximum totalities of 6 minutes 6 seconds and 5 minutes 40 seconds, respectively.
25. This eclipse will happen on April 8, 2024!
Astronomers, whether professional or amateur, are familiar with the uncertainty and limited visibility of some celestial events. Comets may appear bright if their compositions are just so. Meteor showers might reach storm levels if we pass through a thick part of the stream. A supernova as bright as a whole galaxy is visible now, but you need a telescope that can spot it. In contrast, the 2024 total solar eclipse will occur when we say, where we say, for how long we say — and in the daytime, no less. Guaranteed!
