I could only guess that what I saw was a flash from an extremely high-orbiting satellite. I had observed such satellites before, but only dimly through a telescope. Some online research quickly revealed that several observers have seen or imaged these events. One remarkable instance occurred the night of Feb. 22/23, 2022, when Peter Meadows of Chelmsford, England, recorded a 2nd-magnitude flare from a bright geosynchronous satellite near Betelgeuse in Orion. His investigation revealed that it was light reflecting off solar panels from a Superbird B1 communications satellite.
After reading about Meadows’ capture, I went out again the following night and, indeed, spied the culprit around the same time, farther east of Delta. I also imaged the satellite appearing to slip eastward against the stars as the Earth rotated — a telltale sign of either a geostationary or geosynchronous satellite.
Geostationary and geosynchronous satellites vary in size, from about that of a watermelon to that of a pickup truck. Since they orbit some 22,200 miles (35,800 kilometers) high (or about 100 times farther than the International Space Station), seeing a glint from them seems almost impossible. Yet, as the evidence shows, under the right conditions — namely, around opposition — a satellite’s solar panels can cause Sun glints bright enough to be seen without optical aid. From my latitude (roughly 20° south), geostationary satellites lie about 3° north of the celestial equator; the fact that the satellite I observed was next to Delta Aquilae (declination of +3°) confirms this suspicion.
The purpose of this column, however, is not so much to get you excited about the possibility of seeing a nova or a geostationary satellite, but to inspire you to make constant visual sweeps of the night sky, which might just open your eyes to new wonders. As the journalist Loudon Wainwright wrote in the Nov. 24, 1967, issue of Life magazine about Alcock and his passion for the stars, “The key to discoveries like Alcock’s is great familiarization with the sky.” Or, as Dahl says, “Experience … will be of value only if you continually try to improve your own ability.”
As always, feel free to share what has opened your eyes to the sky at sjomeara31@gmail.com.
